Re: Bondo Fiberglass Resin Jelly
I think what you're talking about are stress cracks. Hairline cracks in the surface (gelcoat) of the boat. You have to grind them out to fix them. Gooping over them with anything, doesn't matter what it is or how strong it is, will result in the cracks coming back. Also, you need to fix those with gelcoat, not fiberglass resin.
You either got hit in that spot, have rot on the other side, or have an area of your hull that is flexing for some reason.
Regardless, stress cracks are there because the subsurface is flexing (or flexed once, like if you whacked a dock really hard). Gotta fix that first, then fix the crack. See my site below under the section "fixing stress cracks" for more info.
