Bondo railing holes
studders
just a question here. I was thinking abkut taking my rails off that go around the bow. I’m going to have all them screw holes that’s going to be a eye sore lol. What could I use if it’s possible to fill in those holes and make it look not so bad. Thanks
JASinIL2006
In addition to 3M 5200, you could use a 2-part epoxy (e.g, PC-11, MarineTex) or you could fill with some sort of thickened polyester resin followed with a top coat of gelcoat. The easiest would be 5200 or epoxy. Resin/gelcoat would give you the option of trying to color-match the boat so the repairs are less obvious.
BRICH1260
If you are concerned about appearance, I would fill with epoxy to just slightly below the surface and top coat it with matching gelcoat.
JASinIL2006
I was under the impression that generally, gelcoat doesn't adhere very well to epoxy.
polish up some stainless button head screws and install them in the holes.
Redfred1
Ditto on what Scott said. Hit HD or Duofast; get a bag of stainless beauty washers; then reinstall the screws;
JimS123
Yup, just put new shiny screws back in the holes. No one will know the difference.
Funny question, thought. Every boat I ever had that didn't have a bow rail, I put an aftermarket rail on. Not having a bow rail just isn't cool.
Davetowz
I have to go along with what Jim said above. Just curious why you want to remove the Bow rails. That said, I have used 6-10 epoxy to fill holes like that, then sand smooth. Use tape on the underside if you can reach it to keep the epoxy from dripping and sagging. I use package tape for that.
studders
Thanks for all the input. The reason I was wanting to remove them was I broke a end piece off a few years ago. I’ve been looking for that long on the right one to fit. I’m just about done with it lol. Not unless someone has a link or where else to look. I have looked at quite a few websites and marine shops around the area and nothing will match up along with no one at the shops seem to be able to help me find one or even know where to get one. Yeah they are cool I guess but I don’t know or think it will look at all that bad without them. It’s a older boat and may only have it for one more season. It’s a 1989 Baja islander 190 if anyone wanted to know
82rude
Each to their own I guess.I hate bow rails and got rid of mine toot sweet.Useless tripping hazard.
JimS123
The reason I was wanting to remove them was I broke a end piece off a few years ago. I’ve been looking for that long on the right one to fit..............no one at the shops seem to be able to help me find one or even know where to get one................... Yeah they are cool I guess but I don’t know or think it will look at all that bad without them.................
Piece of cake. The tubing is sold by the foot. It takes little effort to replace one. Even if they are riveted in place (as opposed to screwed) its a simple matter to drill out the rivets and replace with screws.
If that's too much trouble, simply break off the corresponding piece on the other side, plug the ends with tubing plugs, and tie a rope between the two.
You need to find a better shop. Obviously they aren't on the pulse of the marine industry.
When I said "cool" I didn't mean looks. They are an invaluable aid in anchoring and fishing off the bow, not to mention a safety feature when kids are aboard.
My latest boat does not have a bow rail......it has rails all around the entire boat. Can't possibly trip over them, unless I'm drunk, which only happens after the boat is moored.......LOL.
studders
These rails aren’t high enough to prevent anyone from falling over lol. Thanks for the input. I’ll prob just end up taking them off and getting some new stainless screws to put back in there.
Nothing like sitting on the lake with a cooler full of cold beer
the picture i added is anold pic and not one from where I’m missing the end piece. It’s just to show how low these rails are.
