Bosch equivalent fuel regulator?
Daleg70
I cannot say for sure on the cross reference, although the part looks similar to the VP Part.
My comment is this.
I believe there is a service bulletin that says to remove the small wire mesh screen you see on this part.
I was having fuel delivery issues on my engine. (5.7G) I carefully cut out the screen and my issues went away.
Perhaps you do not need a new fuel pressure regulator at all, just the screen removed.
My screen was clogged with a fine metal -- probably a result of ethanol in the gasoline.
thx --- Dale
fognyc
Thanks Dale.. well aware of the screen getting gummed up and also the service bulletin.. I did purchase the recommended eclip and started getting 50PSI at the rail again. I just need to figure out what's up with the 20PSI at the low side now. :(
