Boston whaler rage 15
Hnu427
Recently purchased a rage 15 that has only been ran 3 times in the last 5 years. It was last ran this summer before being listed for sale. Now I have it and cant get it to run, plenty of spark. Put a little fuel in a few cylinders and it tried to pop off. So now its obvious it's a fuel concern. I pulled the fuel line off at the first "T" to carburetors and turned it over and had hardly any fuel move. Am I doing something wrong, is there a fuel cut off safety relay somewhere that could be causing the no fuel concern? It has had a primer ball installed and still has the original primer button. Can see it has a full fuel filter after priming. Cranks over good with brand new battery, but other than priming the cylinders by removing the spark plugs and adding fuel by hand it will not try to fire on it's own. Any input helps, tyi!
