bottom end seals
jcjoyner
Hi guys I'm trying to find a bottom end seal and gasket set for my 120 hp chrysler out board model no. 1207HC serial no. 5208. I have had no luck. If anyone can help me it would be appreciated. Got it running and it purrs. I drained the lower oil and it was quite milkey. Bought new gaskets for the drain screws, Hoping this could be part of the problem. figured I should rebuild the lower end. I also need a new impellar also since it has been sitting for a couple of years thanks guys If I can get help I'm sure its from you guys. Kind of new to the boat thing, and I love it.
woodsailboat
Re: bottom end seals
If the gasket is fairly simple, you should be able to cut one out of gasket material. I did it on my 7.5 and it worked perfectly.
