Bottom paint over topside paint
dmar11bb
Doing a one part paint job on topside of my 17 foot CC. Simple question I think.?
Do I run topside paint all the way down below water line then paint over with bottom paint? Or paint to a line and start bottom paint below.? I'll post pic
Grub54891
Regardless, you have to sand the bottom anyway, so down to the bottom a couple inches won't hurt. Then tape your waterline and sand away.
dmar11bb
If I can figure out how to properly post pics of my project I will. Started out as a small spider crack repair. Oh boy. It's on now.
look at the photo listing tutorial in the rules and guidelines forum.
Chris1956
A lot of single part topside paints will blister if they are underwater. Hulls can blister under bottom paint, if they are not completely waterproof.
So, I would not put topside paint under bottom paint. Also, if you are unsure about the waterproofness (is that a word) of the hull, use an epoxy barrier coat paint under the bottom paint.
dmar11bb
Ok good to know. Maybe a little more info from me. Boat is tailored. Typical trip is 6 hrs in water, and couple times a year its beaches for wife to sit on sand somewhere. Thinking a true bottom paint may be best. Thoughts? I'm going to try to post pics today
Grub54891
It's a trailer queen. Sort if. I wouldn't bother putting bottom paint on if it's not left in for extended periods of time. I'm doing mine without bottom paint, if its an issue later I'll put it on. But I'm in freshwater.
Chris1956
A boat can stay in water for a week without antifouling paint. After that she will start to get some moss/grass/slime buildup.
In your case, I would not bother with antifouling paint. You can use topside paint on the entire hull, if you like. Topside paint will not blister until about 72+ hours of immersion.
dmar11bb
Thanks for the reply. I'm going to repair a spot on keel where a little glass is showing. Then spot gel coat repair and leave it no anti foul
dmar11bb
I'm finally through 2 coats of topside paint. A ton of sanding but final coat goes on tomorrow. I will attempt to load pics. Using the total boat 1 part paint and after a very rough start I have to say its incredible stuff. One piece of advice, dont bother tipping. It flows out perfectly with just back rolling with a pretty dry roller.
Mderski
Ok so I know I’m months behind on this thread. Any way you can tell me exactly what you did to paint? I’m looking for a complete tutorial but I end up down a rabbit hole and confuse myself even more. I have the same size boat and looking to paint. What type of paint, roller, grit sandpaper, thinners, additives for paint. Anything.
