DYLBOSS
- Aug 11, 2009
- 161
2 part question here and background:
So, I've just spent the past 3 days trying to get the 12 year old unmaintained and chipped bottom paint off of my boat that I just bought last August. I have to say, I'm about all out of elbow grease, and I don't wish this project on my worst enemy.
I've used both Interstrip and Ready Strip, then pressure washed/scrapped it off, which worked ok. This didn't take all the paint off, and left some remnants behind, as well as the epoxy layer. My goal is to get everything off and back down to the original surface and leave it as is. I trailer the boat and never leave it in a slip.
I just spoke with a local boat shop that said it isn't safe to do this and that eventually the hull will start to deteriorate, because there isn't anymore gel coat on the hull, due to the surface prep used when it was originally painted. He suggested that I repaint the bottom or re-gel coat the bottom (which sounds way out of budget for the latter).
Does this make sense? Also, I really would rather not have any bottom paint, but if I must I was hoping to paint it with white paint. Has anyone seen this color bottom paint?
Thanks.
Thanks.
