Re: Bottom Painting
Sanding creates little hills and valleys in the surface, which increases the surface area and gives the paint a surface it can hold onto. It is the same reason that a tire slides on ice, but sticks to dry asphalt. If you do not sand, that paint will peal off in large chunks as soon as you get on plane....
