bottom prep what grit paper to use
cpt ron jc
i powerwashed bottom i do not get a lot of buildup any since i trailer,the hull was painted when i bought boat iwant to sand and recoat bottom,what grit paper should be used 100 150 200,and steps aft to recoat.
Don S
Re: bottom prep what grit paper to use
Moving to restoration forum
redfury
I'm currently trying to sand the bottom of my boat using 120 grit discs...it's slow going. It depends on how much of your original finish you want to keep in the end though I suppose.
cpt ron jc
thanks AD i will start with 100 or 120,see how it does,i will check out links y sent,i was told to just sand lightly then wipe with solvent i guess as long as bottom is sanded somewhat and clean it should be ok,the bottom paint cost 100 a gal at west marine yikes have fun rc
sasto
We have ours done with 80 grit just enough to scuff it up so the new paint will stick to a clean surface. After 6 years of doing this annually we removed all the paint and started over. Be safe.
Yacht Dr.
Hi ron..
What bottom paint ? Obviously not VC17 ( they dont sell in gallons :) ).
Normally a light scuff with 80 or 120 after the loose stuff is off.
I like to use a drywall sander with a pole as not to get too much on me.
USE a respo..and a protective suit and gloves Please :)
YD.
cpt ron jc
thanks yacht doc thats a good idea with the pole sander,i have a small polisher grinder,the paint is west marine brand,i trailer so i guess it should be ok,i will start with 80 -120 scuff clean and paint
