Bottomless Pit
seadog2be
Ok, Been thowing money at this boat for past 2 years. great boat. so long as it stays on the trailer. LOL.<br />1979 Rinker Deep-V<br />3.0 L <br />Merc out drive<br /> Had shop winterrise it. Found cracks in the end plate on ex-manifolds and block. oil is ok and cyl pressure ok. talked to lawyer. he said good case. just need retainer of 5000.00 to start. he said if we win I probly still not get paid. so I dropped that idea.<br /> I started looking around for new block. Mine is made of cast. seems all the others are made of gold.. Any way, found a 350 marine motor with omc out drive. I would like to swape 3.0 for the 350. <br />Problems<br />OMC drive comptly differnt. <br /> I need all new cables and have to cut a big hole in transom. <br /> Also need the cupling between the flywheel and trans.<br /> is swaping Merc to Omc Good or bad Idea<br />Next idea is to keep the merc drive.<br /> I need to swap out gears in drive. Where do I buy Parts or used drive.<br /> will 350 manifolds hook up to 3.0 merc drive<br /> Where to buy Parts used or new fine with me<br /> will 3.0 flywheel and trans cupling swap to 350.<br /> 3.0 L and 350 Swap out??? trans same on the two?<br /> Should I count My losses and let the thing burn '''
a.d.mobile
Re: Bottomless Pit
Is the OMC a cobra or stringer? white or silver paint or gray paint?
a.d.mobile
Re: Bottomless Pit
Heck no water in oil good compression. Is it just leaking water? if there just cracks then plug em and have fun is a option. I have seen JB weld is some wierd places.
KaGee
Re: Bottomless Pit
The OMC/Merc swap is not do-able.<br /><br />The 3.0 to 5.7 is not worth the cost on that old of a boat. If you want more power, buy another boat.<br /><br />Why won't the shop help you out?? Other than seeking a lawyer, what else have you done about it??
Laddies
Banned
Re: Bottomless Pit
In anwser to you question NO. The unit you are looking at is a stringer, they were junk when OMC built them, thats why there availabe the newer ones (400 and 800) were better but still not good---Bob
Laddies
Banned
Re: Bottomless Pit
I don't know what stae you live in but here in Michigan you could get your invoices and facts together and take that shop, to small claims court, yourself without retaining a lawyer. You might not get the full amount of your loss, but you would get a judgement for some of the lose and the satisfaction of them having to face their mistake. Once you get the judgement in your favor you can badmouth them all over town without worry of a suit from them. EMBARRASS THEM IN THE COMMUNITY--Bob
seadog2be
Re: Bottomless Pit
The drive i bought was an omc stringer. <br />I have a pre alpha Merc drive now for 3.0<br />Shop is a guy who has been doing boat work on the side for me for past 10 years. He said he did it right and i am just trying to screw him. He dont have the money to fix my boat. However he did say he would keep his eyes out for a block for me. <br />I tore in to the motor the other night. found most of the cracks. fired up my torch and welded them up. I used a cast rod, drilled and preped all cracks. I figured it was allready junk could not hurt. I but the motor back together and ran on muffs. I found a few more cracks. that i will weld this week end. Thanks for your replies. As for the motor re power to the 350 gave that idea up. to much money. I just run this one till she sinks or blows. thanks again for replies.
