Bought a 5.0 mercury kicker 03
Clarko1988
I have a 19 ft marline open blow 2800 pounds will this trolling motor put me around for fish? Its an 03 5.0 mercury
QBhoy
Certainly…as long as the bracket allows the prop to reach low enough to be taking a flow of water from under the hull and not just behind the transom.
The kicker will push the boat fine unless you are in heavy wind/current. Then you may need the main motor
