Bought a boat that's been sitting under a tree for 2 years...cleaning help!
ahyatt
Hey everyone..I just bought a 1973 Charger fiberglass boat that's been sitting under a tree for 2 years...it's been sitting there through multiple hurricanes and has never been covered up...needless to say there's a bunch of dirt, mold, and mildew sitting inside and I was wondering if anyone had any suggestions (cheaper the better) to cleaning up the inside so I can see the white floor again? Are there any cleaners or combination of cleaners that work the best?<br /><br />thanks!
RubberFrog
Re: Bought a boat that's been sitting under a tree for 2 years...cleaning help!
I imagine cleaning it is the least of your problems. All that weather probably rotted out all the stringers.
Gone
Search is your friend!
ahyatt
there is some rot under the driver's seat, but hat that it's pretty sound structure wise...I couldn't believe it...will do a search
studlymandingo
Ditto on the rot, if there is some under the driver's seat, there is probably more hidden under the floor. <br /><br />As for the cleaning, start off with a bunch of bleach, that will remove a lot of the black crap. I use an oxidizing powder with a stiff brush for brightening up. Rust stains and some of the other toughies will come out with some CAREFULLY used muriatic acid. You will need lots of elbow grease as well. <br /><br />I would not recommend mixing all of these cleaners, it may explode or cause you to grow a thumb out of your neck or something! ;) <br /><br />You really need to check for rot!
deejaycee_2000
use a high pressure spray cleaner and then scrub the rest with sugar soap ...
tashasdaddy
i have found Formula 88 to be a great around cleaner. auto parts stores.
JasonB
After you get it cleaned up, you will know why our 19'er is named "Elbow Grease). Simple green works well. Starbrit makes a vinyl cleaner that I've had good luck with. We had to clean up a year or two worth of pine droppings....
crazy charlie
The first thing you need to do is fill a pump sprayer with a 50/50 solution of water and bleach and spray it everywhere .You have to get the organic stains and growths killed dead before you do any scrubbing .You may have to leave it for 10-15 minutes to kill it.It will really brighten up from there.It will also allow any wood to eventually dry out that is water logged.The mildew and growth will keep the wood damp forever until you kill it.
magster65
I'm with crazy charlie, the bleach solution works great.
Animal223
For the vinyl and other textured surfaces, I've had great luck with the Mr. Clean magic erasers. May not work so good on mildew, but for the dirt and general grunge on the vinyl, they work wonders. Also keeps from having to get bleach on the upholstry threads.
cougar1985
for white fiberglass i had great luck with spray nine.my boat also lived uner a tree and spay nine did wonders.
