I just bought a 2003 VIP vision with merc Alpha1 4.3L V6. I know nothing about inboard engines. It seemed to run fine on the test run with the seller, except for a little water in the bilge, and a non operating speedo and tachometer. I was getting a very good price (at least I think so) so I went ahead and purchased it. The boat interior and hull wwas well maintained and super clean, so the way I figured it, even if I had to do some repairs on the engine it would still be worth it. So...
I took it out on the lake twice this weekend. 1st run, I still had water building up in the bilge.
However, I noticed some new problems. After about 30 minutes of being on the water, I started to notice a good bit of smoke coming from the engine compartment. I opened it up and saw that the smoke was coming out of the two hoses that connect to the air filter (pcv hoses I think theyre called?) I also started to notice my fuel guage going crazy, wildy swinging from right to left. Also my oil pressure had dropped. I stopped the engine and let it sit for a few minutes. I checked the oil and it was low. I did not have any oil with me, except an almost empty bottle of penzol 10w-30 that the previous owner left in the storage compartment (I think thats what he was putting in there).
So I went to walmart, got some oil recommended for mercruiser engines (quicksilver 25W-40) called a buddy who told me to check this and that, filled up the oil, filled up the fuel tank, drained the bilge, and put it back in the water. No smoke. Fuel guage good. 30 minutes later, smoke coming from pcv hoses, fuel guage going crazy and water in bilge.
I am planning on taking it to a mechanic to check all of the serviceable items in the transom assembly, like bellows, hoses and housings. Hopefully that will cure the leak.
2 questions: 1) about how much should it cost for a mechanic to check and replace servicable parts in gimbal assembly? 2) could the fuel guage issue and smoke be related to water in the bilge? 3)If not, what are some possible causes of the smoke and the fuel guage problem?
