Mark42
- Oct 8, 2003
- 9,334
Latest project is putting in hard wood flooring. Borrowed a Bostitch flooring nailer from a friend (about a $500 air nailer) but they could not lend me their compressor because they use it daily on the job. A few calls to the local rental stores made me realize that I will be running up rental bills fast because I will have to rent the compressor 5-8 times to do the job unless I burn vacation time (which I am unwilling to do).
So I looked at cheap compressors that will run the nail gun. Found this one at Harbor Freight:
It is a 2HP piston compressor, with a max usable 115 PSI. and 4.4 SCFM @ 90 PSI. More than enough to run the nail gun at the pace I will be working at. Normally sells for $130, but its on sale for $80 right now.
The compressor gets rave reviews from users on HF. Also checked other sources for similar "made in china" 2hp, 4 gallon pancake compressors. Found this same unit is sold under different names (even Sears sells one from WEN). Prices ran from $160 (WEN) to over $250 for some other brands. Downloaded the manual, and it is the same machine, although there are minor changes to handle placement and gauge locations. Parts for the compressor are identical between HF and these other retailers. And where available, they also had good user reviews.
So I bought one from Harbor Freight. Came yesterday. It is a nice little compressor, and is a lot quieter than the reviews said and what I expected. I can easily work with this inside in the same room. It pressurizes the 4 gallon tank quickly to 120 psi, then shut off. Set the regulator to 40 psi, then opened the ball valve and let it drop off. It kicked back in at 80 psi and even with the valve open, ran back up to 120 psi before shutting off.
So I am happy. Its obvious there are some cheap parts. The brass fittings look to be low grade brass. Disassembled the pressure on/off switch and it is a quality part. The gauges are low grade, but Home Depot has replacement gauges that are much larger for about $6 each (tank pressure and regulator pressure). Had to fill it with compressor oil and it has a nice dip stick and sight glass to determine the oil level. The satin black paint job is low quality, and they missed a few crevice areas that show rust already. Also almost every washer that holds the compressor cover on has rust. The screws are OK. Nice heavy gauge 6 ft cord. Found a label that had date of manufacture as 05-10-10. I'm guessing May 10th of 2010?
Funny how the manual says not to use an extension cord with the compressor, but on the box it says it is great for roofers running nail guns due to low center of gravity. How do you operate this compressor on a roof without an extension cord? I guess they expect the roof to have outlets or use your "low center of gravity" generator. LOL!!!!
Still waiting for new 3/8" hose and quick disconnects that were ordered. Should be here Friday, and then the compressor can be tested with the nail gun. If it works well, the plan is to remove the motor from the unit, and paint the entire tank and handle with Rustolium before it has a chance to rust. I like the WEN blue color. Looks nicer than the satin black. And the unit I got from HF has a slightly different handle locaton than the pic above, in fact it matches the photos of the WEN unit exactly.
One last thing. I could hear that there was something that sounded like sand inside. Removed the drain valve and dumped out 1/16" or smaller ball bearings. There must be a cup or so inside the tank, and I'm sure they were put there intentionally. Any idea what purpose they serve?
Anyone else own this little compressor? Comments?
