Here's a pic, for what it's worth:<br /><br />
<br /><br />I paid $500 for it. The hull itself is in pretty good shape, anything that was obvious was patched with epoxy. The transom has no major problems (a few minor cracks on the inside, none on the exterior).They only appear to be stress cracks, not all the way through. I was told that if I tilt the engine all the way up, and put my weight on the engine, the cracks would get bigger as I added weight...but only if they were all the way through. These dont change with weight added, so they are probably minor.<br /> The engine, however, isn't running correctly. It will idle fine, but when you go to get out of a hole and get on a plane, it doesn't have power. It will only go ~10-12mph where it used to go 35. The problem was on-off at first, now it is constant...It is a 65Johnson, btw. I believe a 72 year model.<br />However, it is probably something fairly easy. I think I did pretty good for the money I spent. Oh yea, the trailer is in good shape as well. I bought it from a trustworthy friend, so that helps.<br /><br />Who else has a chrysler, and what do you think of it? Did I get a good deal, or did I waste my money?<br /><br />Thanks!<br />Shawn
