Bought new 4.3 block, do I need new exhaust too?
brsox88
So my 4.3 block cracked due to not being winterized by previous owner (milky oil started coming from the header/valve cover vents) so I bought a new block from RapidoMarine and have a local marine mechanic coming to help me do the change over, timing, etc.
My question is, should I buy all new exhaust manifolds and risers even if the engine ran very smooth and quiet before? Like wouldn't I have heard something if water was trying to re-enter the engine? Or can I just give it a very good cleaning and look over?
Ayuh,.... The manifolds can be blocked off, 'n pressure tested with air,...
The risers can be inspected, 'n or replaced if issues are found,....
brsox88
Thank for the answers so far, do you guys know of an easy guide to test with the ways you mentioned? I assume I just block off one end and fill with acetone to see for leaks, sounds expensive as its like $8 a quart where I am.
tlewis1
Check in the Adults Only section there is a method for testing the manifolds
tpenfield
I am thinking if the engine block cracked due freezing, the manifolds probably did too. :noidea:
