It would have the same mass parked in the driveway as it would going down the road at 200 mph.What's the mass of your boat travelling highway speeds?
It would have the same mass parked in the driveway as it would going down the road at 200 mph.![]()
Unless I'm losing my mind ( a real possibility) mass is weight times velocity
Yep your losing it.![]()
mass is volume times density
or force divided by acceleration.
momentum is mass times velocity
I think you got a mix of all three![]()
What are you saying? ......My density is accelerating towards critical velocity?
The chain needs to be only as strong as the hull where the bow eye mounts.![]()
well, if you want to get technical... it probably has .0000000000000001% less mass at 200 mph. As you approach the speed of light your mass turns to energy.![]()
