When I got home I tried to lower the winch, but it was already bottomed out on the post on the trailer that holds it. So I cut the post off 4" and lowered the winch assembly that same amount, which now is as low as it can go. I thought I had solved the problem until we took it out yesterday, and nothing had changed that much, except now with the bow eye above the roller, hits on it-and then the bow hits the roller.
Getting on and reading posts on this forum, I see that the bow eye needs to be under the roller to stop the boat from moving forward in a panic stop. This would require putting everything back around where it was before I did all my work, but the problem of hitting the roller with the bow would still be there.
The only thing I can think of is to raise the bunks on the front, but that would make the boat unlevel when on the trailer. I can't believe that lowering the winch assembly 4" didn't stop the roller from hitting the bow. I also saw that the bunks need to be spread around an inch when I took these pictures, as one of the rails is hitting the side of the bunk, but that can't affect the problem I have.
Any ideas?
