Bow light not working
mattsylvan
my NEW bow light is not working. i have power to the light and i believe im not missing a ground somewhere. any suggestions?
tashasdaddy
Re: Bow light not working
if the meter say you have power between the ground wire and hot wire, and you are sure of your connections, get a reading inside the fixture, have you checked the bulb for being good.
mattsylvan
i read power at the wire that connected to the light and it still doesn't work but i think im missing a ground somewhere
Nandy
Pull the bulb out. Check for voltage in the bulb fixture, if you have voltage replace the bulb. If you don't have voltage then something is loose. At that point you can start backtracking the voltage in the cable.
Splat
heck the voltage AT THE PLUG between the positive and negative terminals.
BIll
mattsylvan
tha battery is good and i believe i found the problem i mixed the ground with another wire but thanks for the suggestions
