Bowline knot
SeaDooSam
Hi!
Is the bowline knot a safe not to use when tieing a 18ft bowrider to a dock cleat? I know that when a bowline is under a load it is strong but due to waves, the rope can become loose. Will a bowline be good still? Thanks
GA_Boater
No knot needed. Use a cleat hitch. In case the pics don't show, the link - http://www.boatsafe.com/marlinespike/cleathitch.htm
SeaDooSam
Ok, Thanks, but if I were to make a loop is that a safe knot that I can trust?
fhhuber
When its appropriate... a bowline is the king of knots. it holds with or without load. It will not let the loop change size. It even holds on line types that tend to slip with other knots.
And its relatively easy to untie even after being exposed to high tension.
Its great for dropping a line over a bollard.
But its the wrong knot for a cleat.
SeaDooSam
Yeah that knot on the pictures is the first I learned too and I use it most of the time. Thanks for the additional info
southkogs
One of the lines I have on board has a bowline in one end. I use it to tie to all sorts of stuff (including cleats), and so far I haven't re-tied it in about 3 years :) Bowline is a great knot you can trust, when tied correctly.
nola mike
If I'm really paranoid about slipping, I throw an extra half hitch on the bowline. I used to know all kinds of knots, but now use a bowline 99% of the time.
