Re: Boyancy. thinking about puting a 20 hp Motor on a 14ft flatbottom aluminum Jon bo
I have a 14' xtra wide xtra deep Alumacraft flat bootom. It is rated for a 25. I have a 15 Evinrude on it and is great with two people.
I was going fishing on a rather large lake one time, so I borrowed my dads 25 electric start Johnson. WOW, that thing was fast! I am a speed freak but that was nuts. About 3/4 trottle all day and was alright.
If the hull is rated for a 20, then you should be ok. Just be mindfull of where you place the battery, fuel tank, tackle, and of course...you.
It is more than just the transom that factors the ratings given to any boat.
Even "beefing up" the transom will not allow you to safely add a larger motor than recommended.
Where is the transom and what is it attached to? The gunwales. How thick is the aluminum, how and where are the cross braces and support arms as well as how many? Those gunwales would, after beefing the transom, become considerably weaker due to added stress. That leads to this, hp is hp, engine weight contibutes little at this point, although still a factor it is different. There is torque associated with that hp as well as a constant forward stress being applied to the hull. And reverse adds a negetive stress, or pulling on the hull. These two things alone are enough to cause irreversable damage.
And then, there are the handling characteristics involved. Most noticable of a small boat with too large a motor will be coming off of plane. When you trottle down, you could swamp the boat over the transom from your own wake catching you.
Just my opinion, I never give advise, only opinions.
