bracket for throttle different 4.3LX mercruiuser Thunderbolt V
aayjay
I am looking to do away with the 2 bbl on the 4.3 engine. The 4bbl is a 4.25 inch hole separation, so the existing bracket is too narrow to work. I need to source a part to bolt on and hold the throttle cable. Anyone know what is the part number, or a source that can tell me what to buy for my Mercury throttle/shift control that will support the greater distance between the bolt holes. My solenoid and circuit breaker also mount to this bracket. Will I need to move them to a different location?
achris
More fish than mountain goat
Best place to look at what you need is mercruiserparts dot com
Scott06
I assume you are doing an Ed,ebrock or Webber carb? All dodge has the right part number I bought the same for a 2 bbl to edelbrock conversion new off eBay for a few bucks less (seller apwas boater152). Your solenoid and circut breaker will bolt right to this. If you don't have one you need the throttle return spring #12 as well
