Brand New Boat Owner!
Shem77
Howdy! Im a 45 year old man from Snohomish WA and just acquired my first ever boat, an 88 Bayliner Capri with a 75 Mariner oil injected 3 cyl. outboard. Im just trying to figure everything out and also come up with an ignition as there is no key. I noticed on the ignition it says to "hold in for choke" and that the back of the ignition has 6 wires. Im trying to determine if these actuate some electric choke? Is it needed if I hot wire this? Is there a way to manually choke the engine for cold start? Thanks for any help!
alldodge
The outboard key has a feature that when pushed in a solenoid is energized on the motor that chokes the carb. As long as it is pushed in the choke stays closed
Wiring for the key
Shem77
Hi! Thanks for the info. I have no manual and am trying to figure this out. I ordered a new ignition so have to wait for that.
Alumarine
If that's a mercury control it might be possible to get a key from a mercury dealer. The older controls only had about 10 different keys.
If you can take the boat to a dealer they might be able to match it up.
