Brand new mercury idle problem
tchavei2003
I bought a Mercury 2 strokes 50 HP some weeks ago (I use it in salty water). In the first 2 hours the engine ran perfectly then suddently it died at low speed. I first thought it could be lack of gas since this is a new engine and I didn't know the mileage but it wasn't. since then, the engine would die immediatly at idle and response to lever would take 5 to 7 seconds (reverse was only a teoretic concept). Last week, the merc mechanic spend 3 hours around the engine finding a fuel leak. Yesterday I noted that the engine, that runs much better now (low and high speed), has a rough idle.(I think one cylinder is misfiring). I also noted that he can't maintain idle for more than 2 minutes and when I shift fast from reverse or high speed to neutral it dies immediatly. The engine has 6 hours on it! Is it a question of fine tuning the idle rpm? Any suggestion?<br /><br />PS- I don't know if I'm too strong, but my primer bulb never gets very hard... I suppose it was the fuel leak but now that part is fixed and it still doesn't seem hard...<br /><br />Thank you very much for you answers ))
JB
Re: Brand new mercury idle problem
New Mercs are notorious for such shenanigans during break-in. I take it you are using the recommended 24:1 mix for the first tank of fuel.<br /><br />Once she loosens up and gets on a 50:1 diet she will behave a lot better.<br /><br />Good luck. :)
majormotion
My 2003 90 worked fine from the get-go. I have experienced no engine problems of any kind yet. I do agree with one post tho, the first time I throttle up for the day it sputters for a little before taking off. Then it is fine for the rest of the day.<br />Maybe you have an air leak somewhere. I would think your bulb should pump up pretty tight also. Mine does. If you have an external tank unplug your gas line and see if it pumps up then. With a built in tank I don't know. It should pump up just as tight connected to the motor I think.<br />My engine has about 10 hours on it now.
jim dozier
Tap the carbs with a screwdriver handle while you pump the bulb and see if they will firm up. Despite the fact that its new you could have a sticking open float valve since you have had all these problems.
graddy
JB, I have noticed that in the past you have made hegative comments about Mercury engines. I have owned 3 engines from Mercury and any time I had a problems they take care of it. Sounds like you have had a bad experince.
tchavei2003
thank you very much for your tips... the mecanic was another 3 hours around the engine and finally solved the problems... engine works almost perfect now (sometimes he still stalls when changing fast from forward to reverse or vice versa) but i can live with that<br /><br />thanks again<br /><br />cheers, Tony
