My mechanic built me a new motor for my skipjack. I bought two Sierra brand new 18-1931-1 manifolds. At sea trial I had water intrusion into the Pistons on the port side of the engine. With inspection it turns out the Sierra exhaust manifold had a crack on the inner jacket. I replace this manifold with a new one and started the engine at home and the starboard side did the same thing. We pulled the manifold and exactly like the port one had a crack on the same spot allowing water intrusion into the engine. Mind you the engine has less than 2 hours on it. The manifolds have the exact same casting numbers. 180912. Also one of the freeze plugs on each of the manifolds was leaking. My mechanic said he has never seen such failures. He said it must be a batch of bad castings. Has anyone had the same issue from this particular Sierra manifold? If you have purchased these manifolds be aware of this issue. If anyone has had the same issue please write in this thread.
