Brass fuel fittings
Capt. Stabbin
Can any brass fitting/pipe be used for a marine fuel tank, or is there a special marine type I should should use instead? Thanks.
ZmOz
Re: Brass fuel fittings
Anything you can find should be just fine.
bubbakat
yea I got mine right out of auto parts store
VistaMan
Is the brass going to be attached to any aluminum? If so I believe that this is not a good idea as they may deteriate due to electrolisys. or is that copper?
Actually,<br />If by chance you're talking about the 1st hose-barb, at the top of the tank,...<br />That's Supposed to be a Brass, or Aluminum Check-Valve, per USCG.......
