Bravo 1 gear lube leak
hookncook
I thought I would be a little proactive and changed the gear lube in an 07 Tahoe q7i with a Bravo 1 sterndrive. I changed the lube but now I have a leak coming through, pretty much right at the lower screw, right behind the Pr
Ayuh,..... Welcome Aboard,.... Isn't there a little gasket on that screw, sorta like on an Alpha,..??
