Bravo 1 to Bravo 3 Conversion
Jesse Walter
I have 2 Stingray boats. I recently bought a 2007 250CR with a 5.7-300hp and a Bravo 1. I also have a 2004 240CR with a 6.2-320hp and a Bravo 3.
My question would be can I simply swap these outdrives? I'd really like to have the Bravo 3 on my 2007 250CR. Its in a lot better shape than the 2004 with very low hours on the engine. 6.2 isnt in the best condition.
Scott06
yes you can but depending on the drive ratio you may need to reprop. Best bet would be to see if the 2007 was offered with a 5.7 B3 and what ratio and what props it would have come with to get a good starting point. I would suspect a smaller boat with bigger engine would have a lower (numerically) gear ratio and or more prop pitch than would work in a bigger boat with smaller engine.
Jesse Walter
Finally had a chance to confirm my gear ratios.
Bravo 1: 1.50-1 with a 19p SS prop
Bravo 3: 2.00-1 with a 23p SS props
alldodge
Using the lower B3 on either upper will yield a 2.0
Having 23P now will need to prop up much higher unless you get a 15/19 gear set for lower
Jesse Walter
This would be because I have less HP and torque with the 5.7? What pitch props would you recommend?
alldodge
Need to run the 23's first to see where you are in the rpm range. You might be close
Jesse Walter
Well I'm going to do the swap and see what happens!
Basically I have 2 of the same boats. I took out the new one only once this summer and I can really tell the difference in control of the B1 vs the B3. Control of the boat is much more responsive with the B3 at slow speeds(docking, etc.). I figured that I might as well swap them. Doesn't really cost me anything.... I've owned the 2004 B3 boat since new so it doesn't owe me anything either.. lol
Just some back story if anyone is interested:
A couple years ago the block developed a crack over the winter. I always drain the water but I suspect that the one way drains on the side of the block are clogged and all the water didnt drain. I JB welded the side and its lasted the past 2 years. The boat actually still runs amazing and doesnt leak water. At the same time the interior upholstery is not in the best shape and I've developed a leak of drive oil somewhere behind the engine that drives me nuts because the bilge gets coated with oil. I suspect that its the 90 deg fitting but I cannot access that area without pulling the engine. Its VERY tight on this model.
This summer I bought the 2006 B1 boat that has very low hours with perfect upholstery. Its almost the same boat with a few upgrades. Only down side is that its not quite the hot rod my 6.2 B3 is.
If the swap goes good I'll probably put the 2004 up for sale. Probably wont get much with a cracked block but thats just the way it goes.
alldodge
There are many boats out there that have been repaired the same way and run without issues.
Jesse Walter
Finally got the swap done! Took the boat out for the first time today and the outdrive performed great...for the first 15 minutes. Then the engine started to get warm and the alarm went off. I let it cool down for a few and figured out that it would over heat when I went above 2k RPM. I idled back for a few miles and it stayed just about 200deg. Chilled out near the ramp for a while and made it back without needing a tow so I chalk that a success!
I'm going to take off the raw water pump and see if that's the issue. It seems to run good in my driveway with ear muffs but when I rev the engine I get 2 beeps sometimes. I'm thinking the water pressure or flow might be low. I took the boat out one time last year and had no overheating problems but that was with the Bravo 1.
But the Bravo 3 did great! I'll be able to test more once I get the overheating issue taken care of. Hopefully just the impeller need replacing.
