CLi87
- Sep 21, 2018
- 215
I'm working on my 1993 Sea Ray Sundancer 290 with a bravo 2 outdrive. My engine dropped a valve 3 years ago so it's been sitting for awhile, the drive was working perfectly fine when I parked it, I just recently got around to putting in a new engine and to my surprise when I tried to install the outdrive, I found the input shaft doesn't turn at all by hand. If I use a breaker bar I can turn the input shaft a tiny bit in both directions so I know the gears aren't locked up. The outdrive shifts fine into FWD, neutral and REV and the propeller spins fine. I took the top and front covers off the upper and can see the shaft spinning, no rust and I drained the fluid and there was no water intrusion and no metal particles on the plugs. This problem has got me really confused, the assembly is pretty straightforward so I have no idea why it's stuck.
