- Jul 18, 2011
- 18,285
As I prepped my boat for seasonal launching I noticed that the u-joint bellows are showing signs of wear from chaffing along several ridges of the bellows. At least from what I can see with the outdrive tilted up. I have not known chaffing to be an issue, at least based on my previous Bravo outdrive. Otherwise the bellows look fine. I wonder if they were installed wrong by the PO ? . . .
Anyway, rather than run the risk of a wear-through hole developing, I am going to replace the bellows - both outdrives, as I have twin engines. This will be my first venture into bell housing disassembly, but stuff like that has not stopped me before . . .
I replaced the gimbal bearings over the past year ( one last year and the second one this year). Just looking for any words of wisdom, experience, etc before I dive into this. I'll be ordering the parts today with quick shipment and hopefully tackling this over the weekend. Got to do 2 outdrives, which should be 'fun' x 2.
:facepalm:
What tools should I order vs do a makeshift? I figure that I will need the bellows expander, the water line fitting tool, the hinge pin tool, but can improvise the others?
I plan on buying OEM bellows and adhesive and not aftermarket . . .
TIA for any words of wisdom and experience.
