Dumb question alert. – newbie to Mercruisers.
All new Bravo 3 installation and I just need to install the sterndrive.
However, before installing the sterndrive the manual states “With the gear lube monitor cap removed; to purge air from the system, push in on the dribble valve stem until the new gear lube appears.”
Well how long does this take and is there a secret?
I know the tubes are small in diameter and it may take a while but I have pressed so long on the valve stem I have a permanent imprint on my finger … ha ha.
The lube monitor is full and the gear lube is past the quick-connect connection.
One thing I have not done is trim the hose and re-routed, so may have a low spot so wondered if that may be a cause? I am basically looking at the route of the monitor hose from the gear lube to the gimbal housing before cutting the hose.
Thoughts would be appreciated.
Thank you
Thank you
