Bravo 3 driveshaft pinion bearings 8M0104358
homelite
Anyone know the numbers off the bearings and races for this set? 8M0104358 I didn't take it apart yet but don't really want to spend over $300 for 2 bearings.... Thanks
Fun Times
Thinking the chance for this question may be a bit on the low side here to get an direct answer but one suggestion could be try image searching the part number to see if you can pick out the numbers with the bearings sitting out of the box.
That mentioned, the guys over on Offshore Only forums might have some to go look at in the shop/garage.
Here's 2 examples of searching the part number under images of many others.
Good luck.
or pull the whole thing apart, inspect everything, then buy what you need as you will be able to read the bearing numbers, seal numbers, etc.
