I noticed gear lube on my garage floor and it appears a fitting is broken next to the speedometer fitting in the lower drive. The broken fitting I found there is straight but it appears there is not enough hose to bend and connect the two pieces together. Does anyone know the part number or name of the fitting I apparently need.
