boatingedge
- May 6, 2005
- 33
Hi Guys,
I am looking to replace my Bravo III drive due to corrosion issues on the lower unit. I have fixed the corrosion issue so it shouldn't occur again, however my questions are regarding the replacement drive. I am not able to remove the drive as it is currently in the water, so I was hoping someone could tell me what the gear ratio of the drive most likely is. It is on a 1996 Maxum 2700 SCR (sport cruiser) and has a 7.4L 300 hp carb engine. I have access to a drive that is a 2.2 ratio. Will that work?
I was also wondering if the newer style bravo IIIs swap out with the older style units. The newer style being the type that has the two anodes over the prop and the slanted back instead of the straighter back with only
Thanks as always for your help
