Bravo 3 rattle and squeak
Jatsiepup
I just had this drive off and replaced the gimbal bearing. After about 10 minutes of running on the muffs, it started squeaking and rattling which seems to be coming from the bell housing area or upper gears. Any ideas? Thanks.
  • IMG_3765.MOV
tpenfield
Outdrive full of gear oil?
How was the alignment of the engine when you re-installed the outdrive?
Is the gimbal bearing the kind that you can lube? Or the newer kind that is 'perma-lube' ?
