Bravo 3 trim
PLANN B
Unit when all the way down, will not raise with trim or trailer button. When I jump solenoid pump kicks on and will raise unit. I raised to running position and then used trailer button and raised it to trailer position. Solenoid or trim sender unit? Pump will start for down button
Ayuh,..... Welcome Aboard,...... Remove, 'n clean all the wirin' connections on the pump's solenoids, 'n try it,.....
If it still don't work, use a test light to see where it's gettin' power, or not,.....
paulswagelock
It’s free to swap the solenoids, if the problem follows then the solenoid, if not, most likely the trim limit. Alternately, you can get that solenoid for $20 at any auto parts store.
