Bravo 3 water inlet removal
Pavetim
The water inlet hose that goes thru the transom is recessed so i cant tell. How do you remove it? Just twist off or you have to take nipple off from inside?
Pavetim
Well had to pull a bunch of **** to get shift cable in so i will replace water stuff with this kit. I am having a hard time finding the part number for the hose that goes from elbow inside transim down to the flush pro. Idk what year model since cannot find serial numbers. Boat is a 2000 sea ray amberjack 290
alldodge
If your talking about a the kit from transom to bellhousing, the kit is listed above
Pavetim
No the hose that goes from the inside of the transom to the flushpro which then goes to raw water pump. The kit i have but had to destroy that hose to get it out
alldodge
It can be one of 2 types and depends on what your serial number is. The original type was a barbed fitting and newer style used a snap lock fitting. Merc part number 32-8M0062666 and the hose is standard hard wall hose 1.25 ID. Look for shields 16-250-1140-12 as the part number and is sold by the foot
Barbed fitting 22-8M0081543
Quick connect 865470
If the quick connect is used, you will also need the connector for it. In link below it shows parts for newer system. Also has a flush parts.
https://www.mercruiserparts.com/bam/subassembly/31752/13884/250
Pavetim
No pics on ebay but i got this quicksiler kit 32-8M0090859 you know if thats barbed or quick disconnect?
Pavetim
From other pics from other sellers it does look like the QD. The link you posted is from closed cooling and looks very different, still do not see the hose or fitting i need. Ahhhh so the hose is just bulk and not formed? If i use the QD how does that work, adapter goes into the hose and then snaps in?
alldodge
The part is not a kit, its just a 8 foot piece of hose. You probably only need about 4 to 5 feet. The standard length is 8 because its used for inboard and outdrive models
What is your engine serial number?
Pavetim
I will try to find the SN but i know outdrives dint have any. Where is serial number in engune? Maybe easy to see as i had to pull the starboard manifold to get the damn shift cable thru
alldodge
The drive number would be stamped or imprinted on the side of the drive
So far as the hose and fittings are part of the motor, the fitting on the transom assembly can be referenced from the motor or drive.
In the pics above, which fitting was installed on the transom assembly?
Pavetim
You sure the line going from raw water pump to transom nipple is 1.25? I ordered 1.25 hose and flush pro and the line fits snug on flush pro but the hose is loose on the transom nipple. Not sure loose but it should be tighter
alldodge
Yes, that is the correct size, when new its not that tight, after being on for a while with double clamps it is hard to get off
This is a shields piece of hose which I used on my boat
