- Mar 8, 2009
- 42,892
The top of the B3 outdrive only sits about an inch above the water line so the top pin seal is always under water (single engine Formula 27PC). Several years ago I replaced the top pin and seal due to corrosion and water leaking in. Sent the gimbal ring to a company who also made the pin. When it came back there was some slop between the pin and gimbal. Torque on the gimbal ring U-bolt had no effect on play. This season I'm have even more play and I'm figuring maybe I need to upgrade the transom or gimbal. How much slop/play should there be with the gimbal and the square cut pin, and shouldn't the U-bolt be able to squeeze down on the pin?
