bravo gimbal steering pin (hole) wear.
Speakrdude
Ensign
How I measure or figure out, how much wear is too much? The old pin was rusted, pitted, chewed away and super-sloppy!
I have a part now and the gimbal ring may be wore out.
Bt Doctur
before you install it on the boat you would install the pin in the steering arm and torque it to spec. If the pin is not tight in the steering arm ,find out why.
Also recommend installing a grease fitting while apart to prevent this same problem
