6.2L MPI Bravo III Duoprop.
After the boat has been run for a while and is warm, it doesn't want to go into forward gear at the first detent on the shifter. Have to push it a little bit further and then is slams into gear. Makes docking a bit challenging!
I am not sure if it is the little dog that catches the shift cable end at the outdrive when installing the outdrive, or is it is just in need of a shift cable adjustment at the engine?
The service maunuals are a bit confusing for the shift cable adjustment at the engine and I am not sure I know how to do that or if I would just make it worse. Since it happens after it is warm, I belive it is at the lower unit...? any ideas?
