Re: Bravo III Spline Coupler Grease Amount
3 pumps should be enough. You don't want to fill your bellows with grease
the zircs the op refers to are on the coupler itself, there is no way any of the grease they pump there would make it into the bellows
to op - you really should be greasing the coupler via the aft, i.e. - pulling the drive every season and using a long screwdriver with about 1 fl oz of spline grease on the end
this way you can ensure the splines are fully and evenly coated - along with doing other recommended seasonal drive/transom assy maintenance
