Bravo outdrive won't go all the way up
JimJam63
First time boater here. Bought Larson Hampton last year, motor shelled out last season, remotored this year. Came back from shop with drive all the way up. Launched yesterday, cruised around for a few hours motor is great, everything seemed fine but when getting back to the ramp the drive wouldn't go all the way up. It moves but stops about 1/2 was up. Goes down fine, comes up and stops. Could it be as simple as the limiter on the drive just needs adjusting?
thumpar
You need to find the trailer button. Sounds like you are hitting the trim limit for up trim. Trailer lets you go farther. On mine it is a square button in the middle of the throttle handle. Others are hard press of the up trim and there is some that require 2 buttons be pressed. It will depend on your setup.
tpenfield
Trailer switch . . . the regular trim button should only go to the trim limit position, then stop.
