bravo prop seal specs
CamaroMan
Hi - just removed 2 brown inner prop seals from a bravo - the replacement ones were smaller.. OD on the seals are about 1.843" -
whats the difference between Seal 26-861694 and Seal 26-8M0033407?
Is the 26-8M0033407 the same size/dimensions?
thanks
alldodge
I think things are mixed up, these are B3 drive seals and used for inner and outer shafts
seal 26-861694 is used in the outer larger seal area and contains 2 lips seals in one seal
Dimensions 3 - 3/8 OD, 2 - 1/2 ID, 13/16 wide
seal 26M8M0033407 is used in the inner seal area and contains 2 lip seals in one seal
