Hi,
Just fitted new Bearings to my original Bravo Three Drive Shaft and have set the preload for new Bearings. The issue I have now is when fitting the Drive assembly into the housing I find that the pinion gear is tight and binds when tightening the Retainer Nut. I read that the drive shaft may need to be shimmed, current assembly has no Shims. Cannot find any detail related to this in the service manual #28. Reason for bearing change was that initially I over tightened (Preload) ft -lbs instead of inc -lbs, so thought may as well renew bearings.
