Bravo two water tube
Grub54891
Question is, the water tube that was removed is just the hose with the tapered insert that screws in. The new bellows/ tube kit containers the water hose, but the transom end is the hard plastic type that has the grommet and set tool. Is the new one an updated version or did I get the wrong water tube?
Fun Times
It’s a new updated design to help fight corrosion that can occur in that area.
Grub54891
Thank you. I thought that was the case. I just didn’t find it online as an update. It fit perfectly, I’ve installed this version before and the old version a lot also. I always thought that they were just different models/years designs.
Thanks again.
