Bravo Y-Pipe socket. What to use?
Friscoboater
I am having a really hard time with this new search and I could not find anything about the bolts. They have 12 point nut heads. Where is a good place yo buy sockets to get them off.. Northern Tool?
Also does anyone know the size?
Re: Bravo Y-Pipe socket. What to use?
Ayuh,... It's just a standard 12-pt. socket,....
3/8" I belive, maybe 7/16"....
Sears sells 'em....
HT32BSX115
Yes.....I used 3/8 12pt on mine.
The bolts are stainless steel and they go into aluminum. Follow the Mercury torque specs or you WILL either strip the holes or break them off......DO NOT USE NEVER SEIZE on them!! Mercury 2-4-C Teflon Marine grease works great.....
Regards,
Rick
Friscoboater
Thanks guys. I went to sears and found right socket. What was really wierd is that the bolts were not even tight. I just used the socket on the end of an extension and they came off.
Ayuh,... They should be about 15/ 20ft.lbs....
And,..
Don't forget to use a New o-ring gasket....
