Fmfisher80
- Feb 12, 2022
- 1
Just a few times last boating season I had problems with my bravo 3 not going into reverse. Shifter would just not go past neutral tward reverse but no problems going forward. Brand new shift cable, well 2 after I found out 1st was routed wrong. Taking the outdrive off the only obvious thing I can find is the detent pin is very sloppy in the hole on the back cap. Does anyone here know how loose that is supposed to be? Would this cause a hangup only in reverse every now and again? Thanks guys
