Re: break away hubs??
Quicksilver are mostly designed for I/O's such as the Mirage props, Mercury props are mostly designed for outboards such as a the Lazer II, but Both brands can be used for I/O and large V6 outboards, The lazer will give you bow lift and The Mirage will lift at the transom which is most commonly used with I/O's due to generally higher stern weight, I have used both Mercury and Quicksiver props on a Alpha one, but they are used for different reasons, holeshot vs speed etc, you need to try several different brands and types if you can find a prop shop that is willing to let you experiment then you narrow down your choice and not buy the wrong prop, My stainless prop is about 750 loonies new that would be a costly mistake if its wrong, try before you buy, I'm lucky I have cousin that owns a prop shop, so I can try anything I see hanging on the wall, I have even tried props of the same pitch and dia. but different brand names and have different results.
