Briefly - what is a switch box?
Badtracker
Keep reading about reference to a "switch box" in electrical troubleshooting. What is it, and where is it located? I have a 2003 Mercury 50.
aussieflash
Re: Briefly - what is a switch box?
Switch box pretty much controls/distributes your electrics.Your Trigger,Stator,and all spark leads are connected to this box.Just follow the wires.
Badtracker
Will/Can the switch box affect charging? Engine is running perfect off of battery?
j_martin
The switchbox takes power from a separate set of coils in the stator, one set for each switchbox. It stores that power in capacitors, and fires a pulse to a spark coil which is timed by internal bias circuitry and signal from the trigger.
The charging circuit is a separate coil in the stator driving a rectifier, or rectifier/regulator, depending on the engine.
usually, when the engine runs good and it's not charging, it's the rectifier or regulator that is bad. In a switchbox engine, the tachometer signal is taken off the charging circuitry.
hope it helps
John
