Re: british seagull easy to run
Johnny-take the plug out and clean it then put fresh fuel in the tank. At 10:1 mixture it goes "off" quite fast. <br /><br />The best starting procedure for a seagull I've found is:-<br /><br />Half throttle, close air intake, pump tickler til fuel comes out. Pull cord. They flood quite easily so if it doesnt start in 6 or 7 pulls turn the fuel tap off and keep trying. If this doesn't work take the plug out, dry it in a flame and pull it over a couple of times with the plug out. Then open the air intake and try again with the fuel tap turned on. Don't use more than 1/2 throttle when trying to start it.<br /><br />If you're new to Seagulls then get a spare spark plug and a couple of spare drive springs. Carry them with you whenever you take it out. Both are an essential item.
